It will not restart
246,000 MILES • 5.9L • V8 • 4WD
STEVEN GRIFFIN
  • 5 POSTS
When I turn it off, it will not restart, and I have notice that the gauges do not work. so I let it set for about an hour, then I turn the key to run position several times then I noticed that the check gauges light comes on then the gauges jump to where before it shut off, I turn key and it cranks.
Jan 17, 2017 at 9:03 AM
CARADIODOC
  • 34,414 POSTS
What is the symptom when it will not start? At the end you said the starter will crank the engine, but you did not say if it will start and run. Is that what it does when it does not start, or does the starter fail to crank the engine?
Jan 17, 2017 at 9:17 AM
STEVEN GRIFFIN
  • 5 POSTS
It just spins over.
Jan 18, 2017 at 1:00 AM
STEVEN GRIFFIN
  • 5 POSTS
It just spins over until the (check gauges) comes on then it will start.
Jan 18, 2017 at 5:45 AM
CARADIODOC
  • 34,414 POSTS
The first thing to do is read and record the diagnostic fault codes. Do you know how to do that yourself?
Jan 18, 2017 at 6:48 AM
STEVEN GRIFFIN
  • 5 POSTS
No sir.
Jan 18, 2017 at 8:51 AM
CARADIODOC
  • 34,414 POSTS
Chrysler made doing that yourself much easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds without cranking the engine, leave it in "run", then watch the code numbers appear in the odometer display.
Jan 18, 2017 at 9:44 AM
