1999 Dodge Ram No Start With Spark and Fuel
MPINIL
1999 Dodge ram Van truck will not start I am getting gas and spark what should i be looking for next.
Feb 13, 2007 at 6:02 AM
SQM
  • 6,383 POSTS
An engine will need spark, fuel and compression to start.
It can also not start due to a faulty sensor, which can send wrong data to the ECM, and not start the engine.
If the no start is happening due to a sensor there should be trouble codes. Is the check engine light illuminated?
https://youtu.be/vMwTzURWXmk
Many times the engine will crank but not start due to a faulty crank position sensor.
The sensor is bolted to the cylinder block near the rear of the right cylinder head.
Overtime heat and vibration will cause the crank sensor to loose its calibration and it will start to produce faulty or no signal to the ECM and you will have no start.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
You also might want to check engine compression. As a general rule of thumb, you should not have more than 70% difference in compression from the lowest to the highest cylinder.
Compression should not be less than 689 kPa (100 psi) and not vary more than 172 kPa (25 psi) from cylinder to cylinder
Here is a helpful video of how to test compression:
https://youtu.be/J3j85hg0d-4
Aug 19, 2021 at 4:17 AM
Suggested Repair
Confirm spark, fuel, and compression, and scan for trouble codes if the check engine light is on. A common no-start cause is a faulty crankshaft position sensor near the rear of the right cylinder head. Also test compression: at least 100 psi, with no more than 25 psi variation between cylinders and no more than about 70% difference from lowest to highest.
Conversation Summary
The owner of a 1999 Dodge Ram van/truck says it will not start even though fuel and spark are present, and asks what to check next. The expert explains that starting also requires compression and correct sensor data to the ECM. They recommend checking for a check engine light and trouble codes, testing the crankshaft position sensor, and performing a compression test within the stated limits.
