2010 Dodge Ram No-Start Fuel Pump
200,000 MILES • 5.7L • 4WD • AUTOMATIC
JOSH MASON_1
Changed the alternator and put in a new battery and when I put it back together it would not start. The fuel pump is not making any sound. I would like to find out which wires come out from underneath the fuse box under the hood go to the fuel pump so that I can check to see if there's a signal going to it. Not sure but I think somebody said that there may be a bypass that I can do to it if it's something besides the fuel pump.
Oct 11, 2026 at 6:26 AM
CARADIODOC
  • 34,415 POSTS
First, when are you listening for the hum of the fuel pump? If you can even hear it, it only runs for one second when you turn the ignition switch to "run". It doesn't turn on again until the Engine Computer sees engine rotation, (cranking or running). It knows that by the signal pulses it receives from the crankshaft position sensor and the camshaft position sensor. The system is designed to turn the fuel pump off if a fuel line gets ruptured in a crash. Loss of fuel pressure means no fuel will spray from the injectors, the engine will stall, those signal pulses stop showing up, the computer turns the fuel pump and automatic shutdown, (ASD) relays off, and no fuel gets dumped onto the ground where it would create a serious fire hazard. You don't want to bypass the fuel pump relay except as a momentary test.
Same operation with the automatic shutdown relay. It sends current to the ignition coils, injectors, and alternator field, among other places. Bypassing the ASD relay is pointless, again, except when testing that circuit, because the same signal pulses from those two sensors that are needed to turn that rely on are also needed for the computer to know when to fire an injector or ignition coil. Bypassing the ASD relay might get you 12 volts to those coils and injectors, but they aren't going to get pulsed on and off if the sensor signals are missing.
I put the fuel pump circuit diagram and the connector view for connector C6 below. The wire you asked about is pin F13, a dark blue / orange wire. There's a far easier way to test the operation of this system. Look for the wire that is the same color at every injector and ignition coil. On your model, that is the brown / white wire. It has 12 volts switched onto it by the ASD relay. Back-probe that wire at any injector or ignition coil with an old-fashioned test light with an incandescent bulb inside. Most digital voltmeters don't respond fast enough for this test. Prop the light where you can see it from inside the truck, or have a helper run the ignition switch for you.
The test light should turn on full brightness for just one second when the ignition switch is turned to "run". That tells you the relay and fuse M50 are okay, and the computer is controlling that relay. Next, what's important is that voltage must come back during cranking. If it does, you have either an ignition system problem or a fuel delivery problem, but likely, not both. If the test light does not turn back on during cranking, you WILL not have spark or injector pulses. Both will be missing, and you must look at what both systems have in common, which is those two sensors.
If you never see 12 volts on the brown / white wire, fuse M50 is a good suspect, especially since you were working in that circuit. First switch the ASD relay with one of the others like it. If the engine starts, the original ASD relay is defective. Next, check for 12 volts on that fuse. There's two tiny test points on top of it. You'll have to check for that voltage when the ignition switch is turned to "run", and you only have one second to see the results. If you have it on one test point, wait a few seconds with the ignition switch off, then do the test again on the fuse's other test point. If voltage is missing on one point, that fuse is blown.
Let me know how far this gets you. I'll be back tomorrow to see what you found.
Oct 11, 2026 at 4:50 PM
Suggested Repair
Do not bypass the fuel pump or ASD relay except for a brief test. Back-probe the brown/white ASD feed at an injector or ignition coil with an incandescent test light; it should light for about one second in Run and again while cranking. If it does not, swap the ASD relay and check fuse M50. If voltage is missing only during cranking, test the crankshaft and camshaft position sensor signals that control the ASD and fuel pump relays.
Conversation Summary
A 2010 Dodge Ram cranks but will not start after a new alternator and battery were installed, and the fuel pump makes no sound. The expert explained the pump and ASD relay only prime for about one second in Run, then stay off until the computer sees crank and cam sensor pulses. They identified the dark blue/orange fuel-pump wire at connector C6 pin F13 but recommended checking the brown/white ASD feed, swapping the ASD relay, and testing fuse M50 before suspecting the pump.
