Hi:
If the spark appears weak, check the rotor and cap. Make sure there is no corrosion. Also, make sure the coil isn't arching power at another location. If all looks good, see if you can find a different coil to try. As far as the clicking, it sounds like the solenoid is bad on the starter. You will most likely need to replace the starter.
Let me know what you find.
SPONSORED LINKS
Tuesday, December 9th, 2008 AT 1:19 PM
