1988 Dodge 600 Stalls After Start
DODGE
MIKE KERR
1988 Dodge 600 4 cyl 144,000 miles starts and runs for a few seconds but won't stay running. I changed fuel filter. Temp around zero. Would HEET solve my problem?
Feb 7, 2007 at 7:14 AM
  • 75,988 POSTS
Have the fuel pressure check to rule out other things involved in the fuel system.
Feb 7, 2007 at 8:51 AM
BUBBA_KOSKI
  • 129 POSTS
gimme a little more info, and i'll be able to help you, ever happen before, driven daily,etc.
Feb 7, 2007 at 8:52 AM
MIKE KERR
The car sat since nov 06. I picked it up last Saturday and filled up gas. Car ran great until Wed. morning. Temp is about zero and i think gas had some water in it and froze. Also I tried to jump another car with this one, could I have damaged the coil?
Feb 9, 2007 at 12:06 AM
SKETCHBAL1
  • 12 POSTS
Shouldn't have anything to do with jumping the other car. Sounds like a definate fuel problem. Could be a fuel line thats rusted or crimped, or the fuel pump...etc.
Try disconecting the fuel line above the pump while cranking the ignition to get a look at the flow. If it looks good your problem is further up than that.
Feb 11, 2007 at 4:54 PM
Suggested Repair
Check fuel pressure and fuel delivery. Inspect for a weak fuel pump or a rusted or crimped fuel line, and consider water in the fuel from cold weather. Jump-starting another car is unlikely to have damaged the coil.
Conversation Summary
A 1988 Dodge 600 starts and runs briefly, then stalls after sitting and being filled with gas in near-zero weather. The owner replaced the fuel filter and wondered about water in the fuel and coil damage from jump-starting another car. Advice was to check fuel pressure and fuel flow at the pump, and that jump-starting should not have caused the stall.
