1990 Dodge Ram Starts Then Stalls
LISA777
  • 8 POSTS
I have a 1990 dodge ram truck 3/4 ton 4X4 360 motor....It starts fine but won't stay running...any thoughts on this...thanks
Jun 26, 2006 at 4:51 AM
VANDRAGON
  • 298 POSTS
lisa,
edit your question with more info, year, miles, engine type and how does it stall. this will help get you an answer hopefully....vandragon
Jun 30, 2006 at 2:52 AM
CARAVANOGRE67
  • 22 POSTS
it sounds like a dirty fuel filter or your fuel pump needs replacing star with changing the fuel filter first they are cheap if that solves your problem you got off cheap. another way to see if you are getting fuel is take the fuel line off before the fuel filter and put a hose on the metal end secure it with a hose clamp then have some one turn over the engine remember pull your coil wire off the coil first from the coil run the hose into a bottle or can and see if you have fuel. it should just shoot in at a steady flow good luck
Aug 2, 2006 at 5:35 PM
Suggested Repair
Replace the fuel filter first, since it is inexpensive. If the truck still stalls, check fuel delivery and consider replacing the fuel pump.
Conversation Summary
The owner of a 1990 Dodge Ram 3/4-ton 4x4 with a 360 engine says it starts but will not stay running. One reply asked for mileage and stall details. Another suggested a dirty fuel filter or failing fuel pump, recommending the filter first and a fuel-flow check.
