2001 Dodge Ram 1500 AC Compressor Shuts Off
SAMBO77TX
2001 Dodge Ram 1500 V6 120,000 miles
I'm having a confusing problem with my a/c. When i first turn it on, it will blow very cold for a few minutes (depending on how hot it is outside). After a few minutes the compressor switches off and doesn't want to come back on. If i switch the a/c off for a good while (30 mins or so) then switch it back on, it will blow cold for a few minutes again before the compressor shuts off again. There are no leaks, refrigerant level is good, and i have replaced the clutch cycling switch (as per advice) to no avail. I have been told there could be a problem with spacing in the clutch. Any suggestions on this spacing thing (like how to check/fix it) or other ideas on the problem would be greatly appreciated.
Jul 13, 2006 at 1:47 PM
VANDRAGON
  • 298 POSTS
you have to replace the clutch assembly.
Jul 15, 2006 at 7:54 AM
REEGS37
  • 19 POSTS
Sounds like it could be the high pressure switch, which should be located at the bottom left of the radiator but not on the radiator, I had the same problem with my 1996 Intrepid and that was the problem along with my fans constintly running. Good luck.
Jul 17, 2006 at 2:28 AM
Suggested Repair
Replace the A/C clutch assembly. A secondary suggestion was to check the high-pressure switch near the radiator, but the expert recommendation was clutch replacement.
Conversation Summary
A 2001 Dodge Ram 1500 blows cold for a few minutes, then the compressor shuts off until the system rests. Refrigerant level is good, no leaks were found, and the clutch cycling switch was already replaced. An expert advised replacing the clutch assembly; another reply suggested the high-pressure switch.
