1968 Dodge Dart Park Shifter Issue
DODGE
IN2THEKNIGHT
I just got a 68 Dodge Dart 340 (5.6 L) V8 with automatic trans. When I try to put it in park, sometimes it goes into 'R' instead. I have to push the shifter all the way forward and giggle it a little for it to stay in 'P' (and for the shifter button to pop up). Is this a trans problem I can fix myself or should I take it in? (this is my first classic and I only know the basic stuff like tune ups, replacing a heater core, etc)[img:f3b45cf7eb]http://www.2carpros.com/forum/automotive_pictures/67820_psgrsidesml_1.jpg[/img:f3b45cf7eb]
Apr 10, 2007 at 8:29 AM
  • 110,248 POSTS
Hi:
It sounds like there is a problem with the linkage from the shifter to the trans. Check for steel linkage going to the trans under the vehicle. Next, check for areas which are sticking or too loose (worn out).
It may just need lubericated, or bushings may need replaced.
Oct 24, 2008 at 6:38 AM
Suggested Repair
Inspect the steel shift linkage under the vehicle for sticking, looseness, or wear. Lubricate it if needed, or replace worn bushings.
Conversation Summary
The owner of a 1968 Dodge Dart with a 340 V8 and automatic transmission says the shifter sometimes selects reverse instead of park and must be pushed fully forward and jiggled before it stays in park and the button pops up. The expert attributes this to the shifter-to-transmission linkage and recommends checking it for sticking or excessive looseness, then lubricating it or replacing worn bushings.
