Dodge Caliber Stuck in Park
DAVIDLARRYDAVIS
my caliber at times want come our of park
Aug 9, 2007 at 3:21 AM
  • 110,251 POSTS
Dave, I need you to check something. The next time it happens, see if the brake lights are working. The switch for the brake lights sends a signal to the Park lock out switch indicating you have the brakes on. If the switch isn't working, it won't come out of park.
Let me know if this helps.
Dec 19, 2008 at 3:16 PM
Suggested Repair
When the Caliber will not come out of park, check whether the brake lights work. The brake light switch signals the park lockout that the brakes are applied; if it is not working, the shifter will stay locked in park. Inspect or replace the brake light switch if the lights do not work.
Conversation Summary
The owner reports that a Dodge Caliber sometimes will not come out of park. The expert advises checking the brake lights when it happens, because the brake light switch tells the park lockout that the brakes are applied. If that switch is not working, the vehicle will not release from park.
