2000 Dodge Intrepid Heater Core
WALLYS17
2000 Dodge Intrepid how long will it take to replace a heater core
Dec 20, 2006 at 9:28 AM
GARFIELD
  • 197 POSTS
If it is like most new dodges it averages about 8-10 hours for a good mechanic. If you have never done it it can take much longer. Most newer dodges reqire the entire dash to be removed to gain access to the heater core and ac evaporator. None of the aftermarket repair manuals cover replacement. You will need to get the factory service manual to know where all the fasteners are at. The extra cost of the factory manual will save you much aggrevation and will speed the job up. Good luck
Dec 22, 2006 at 12:52 PM
Suggested Repair
Plan on about 8-10 hours for an experienced mechanic, and longer if you have not done this job. Access typically requires removing the entire dash. Use a factory service manual, since aftermarket manuals do not cover the fasteners.
Conversation Summary
The owner asked how long it takes to replace the heater core on a 2000 Dodge Intrepid. The expert estimated 8-10 hours for a good mechanic and longer for a first-timer, noting that the dash usually must be removed and that a factory service manual is needed.
