2000 Dodge Intrepid Coolant in Oil
SMKENDRICK
2000 Dodge Intrepid, 2.7, 6 cly, 2 wheel drive
118,000 miles.
Water temp gauge kept jumping up and down, checked water and reserve was empty, let engine cool, refilled water, drove 5 miles and it happended again. Had car towed home, checked oil no water,
when we drained oil, it had a strange color to it and smelled like gas, it was a creamy camel color, checked engine and no water, no cracks in hoses, no visible wear on belts, what could be wrong??
May 13, 2007 at 8:19 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like coolant is getting into the oil. IF it is now cold and has sat for 8 hours. CAREFULLY turn the oil drain plug back enough so that you are very slowly draining the oil into a clear container. IF it has sat long enough the coolant will seperate from the oil. The coolant drops to the bottom adn is what you may find when you do this.
The 2.7 engine leaves a lot to be desired. Head gasket problem?
May 13, 2007 at 11:17 AM
Suggested Repair
After the engine has sat cold for several hours, slowly crack the oil drain plug and drain into a clear container to see whether coolant has separated to the bottom. Coolant loss with creamy oil suggests coolant mixing into the oil, and a head gasket problem is a likely concern on the 2.7 engine.
Conversation Summary
The owner of a 2000 Dodge Intrepid 2.7 reported a jumping temperature gauge, an empty coolant reserve that emptied again after a short drive, and drained oil that was creamy camel-colored and smelled like gas. No cracked hoses or worn belts were visible. The expert said coolant may be entering the oil and advised a slow drain after the engine has sat so any separated coolant can be seen at the bottom, noting a possible head gasket problem on the 2.7.
