2001 Dodge Intrepid Where's the thermostat and water pump l
146,500 MILES • 4 CYL • 2WD • AUTOMATIC
BIGEDSR
Trying to find the thermostat and the water pump
Mar 16, 2010 at 6:42 AM
  • 110,244 POSTS
The pump is run by the timing belt. You need to remove the cover to access it. As far as the t-stat, follow the upper rad hose back to the engine and it will end at the t-stat housing.
Mar 17, 2010 at 3:43 AM
