Notes: fuel pump "primes" every time key is turned over. No air / gas leaks anywhere. Battery & starter okay. Car starts when starting fluid is sprayed into engine, so we know it's a fuel problem.
Please help. Thank you.
Replace the fuel pump and its broken strainer/screen, preferably with an OEM pump. Confirm at least 5 psi between the tank and filter; if restricting the return line raises pressure, replace the regulator instead.
A 1995 Dodge Caravan with 170,000 miles died repeatedly after a recent fuel pump replacement, despite a new filter and metal fuel line. It primed and started only with starting fluid, and fuel barely sprayed from an open line. The expert said idle pressure should be about 48 psi, and that pressure between the tank and filter should be at least 5 psi; if restricting the return raises pressure, replace the regulator, otherwise replace the pump and check the screen, using an OEM pump. The owner later confirmed the pump strainer had broken and the van ran only when the tank was at least half full.
