1974 Other Dodge Models
1974 DODGE
REX WHITTEMORE
Engine Mechanical problem
1974 Other Dodge Models V8 Two Wheel Drive Automatic 135ooo miles
will start and run sometimes 2minuts sometimes 15minuts is geting spark and fuel replaced coil,dist cap,rotor,voltage regular,control unit,ballast, it will just quit like you shut it off will restart,fuel pump is putting out plenty of fuel, help
May 25, 2009 at 3:38 PM
HMAC300
  • 48,601 POSTS
chrysler was notorius for haveing bad wiring systems. Check to see if your iginition switch is burnt around it as it may be losing contact there and doing what you are describing.
Oct 8, 2009 at 2:43 AM
