I have a 1995 dodge van 318ci b2500 with 140,000 miles on it. About 4 months ago I had the fuel pump replaced. I don't know if it is a coincidence but during cold weather ( under freezing ) she won't start until after I sit and wait with the key in the on position for a variable amount of time. Then I hear the fuel relay start clicking quieter at first then becoming louder towards the end and just before it stops the check engine light starts flashing in unison until it stops and then I am able to start the van normally. The colder it is outside the longer this process takes. In warmer temperatures it starts immediately. I replaced the fuel cutoff relay and it does the same thing. Any thoughts? Thanks
1995 Dodge B2500 Cold No-Start
The ASD relay is activated by the computer-verify the relay if its the ASD-the ASD relay powers up the coil and pump. This relay if its defective you'll get the same symptoms.
Suggested Repair
Check for spark and fuel while the no-start occurs, and verify the ASD relay because it supplies the coil and fuel pump. The owner later reported that replacing the ECM resolved the cold-weather delay.
Conversation Summary
A 1995 Dodge B2500 van with a recently replaced fuel pump would not start in freezing weather until the key was left on and a relay clicked for a temperature-dependent time; it started normally once warmer. No trouble codes were stored, and a replacement fuel cutoff relay did not help. Testing showed no spark or fuel until the relay energized, after which the pump pressurized. The expert advised checking fuel and spark and verifying the ASD relay, which powers the coil and pump. The owner later reported that a failed ECM was diagnosed and replaced.
