1979 Dodge Omni Battery Won't Charge
SHEEHAN
I have a 1979 Dodge Omni and the battery won't stayed charged. I've replaced everything I can think of. Has anyone had a similar problem - how did you fix it?
John
Dec 27, 2006 at 5:36 AM
STRATUS98
  • 96 POSTS
check the grounds, make sure terminals are clean
Jan 2, 2007 at 12:14 AM
CARADIODOC
  • 34,413 POSTS
These have an alternator mounted on rubber bushings to reduce vibration. Since it is isolated, it needs an external ground strap or wire. The straps rust apart quite often resulting in a no-charge condition.
Mar 19, 2009 at 9:06 PM
Suggested Repair
Inspect and replace the alternator ground strap or wire, which often rusts and causes a no-charge condition because the alternator is isolated on rubber bushings. Also clean the battery terminals and verify all grounds.
Conversation Summary
The owner of a 1979 Dodge Omni said the battery will not stay charged despite replacing many parts. One reply suggested checking grounds and cleaning the terminals. The expert explained that the alternator is mounted on rubber bushings and needs an external ground strap or wire, which commonly rusts apart and causes a no-charge condition.
