1999 Dodge Caravan Dash Gauges Dead
DAVIDSTJOHN
Hello,This is a 1999 Dodge Caravan.There is nothing working on my dash(Fuel,Speedometer or Temp Gauage)also it does not show anything else such as door is ajar or what gear I am inor how many KM is on my van.Can you help me with the problem and maybe give me a solution.Thanks Dave,Calgary,AB
Dec 5, 2006 at 12:10 PM
GARFIELD
  • 197 POSTS
You may want to check and see if you have a blown fuse or look for a loose or disconnnected electrical harness at the dash instrument panel. How long has it been doing this?
Dec 5, 2006 at 9:15 PM
DAVIDSTJOHN
dode caravan 99 176000
Dec 6, 2006 at 2:46 AM
Suggested Repair
Check for a blown fuse and inspect the dash instrument panel electrical harness for a loose or disconnected connector.
Conversation Summary
The owner of a 1999 Dodge Caravan reports that nothing on the dash works, including the fuel, speedometer, and temperature gauges, plus door-ajar, gear, and odometer displays. An expert suggests checking for a blown fuse and a loose or disconnected harness at the instrument panel. The owner later noted about 176,000 km but did not confirm a repair.
