1997 Dodge Neon Battery Won't Stay Charged
HOPKINS30
I have a 1997 neon m: 157k started overheating about a month ago, replaced the thermostat, ran fine for a few days started over heating again. Found out fan sensor needed to be replace, done. Ever since the sensor was replaced the battery will not hold a charge, bought new battery, replaced alternator. If jumped will only stay started for about 6 minutes. What else could be causing this problem please advise asap.
Sep 12, 2006 at 2:10 PM
BUBBA_KOSKI
  • 129 POSTS
when replacing alternator make sure shes istalled on a new or fully charged battery what youre saying about jumping it, and cuttin off bout 6min is your alternator have her tested at an auto store
Sep 27, 2006 at 4:15 PM
Suggested Repair
Have the alternator tested at an auto parts store, and install or test it only with a new or fully charged battery.
Conversation Summary
A 1997 Dodge Neon began losing battery charge after a cooling-fan sensor was replaced. A new battery and alternator did not fix it, and the engine stays running only about six minutes after a jump. The expert said the alternator should be installed on a fully charged battery and tested at an auto store.
