79 Omni - Battery won't stay charged
1979 DODGE OMNI
SHEEHAN
I have a 1979 Dodge Omni and the battery won't stayed charged. I've replaced everything I can think of. Has anyone had a similar problem - how did you fix it?
John
Dec 27, 2006 at 5:36 AM
STRATUS98
  • 96 POSTS
check the grounds, make sure terminals are clean
Jan 2, 2007 at 12:14 AM
CARADIODOC
  • 34,381 POSTS
These have an alternator mounted on rubber bushings to reduce vibration. Since it is isolated, it needs an external ground strap or wire. The straps rust apart quite often resulting in a no-charge condition.
Mar 19, 2009 at 9:06 PM
