why is car losing coolant?
HOCKMASM
99 dodge Neon, 130,000 miles, 4cyl Single Overhead cam, stickshift
I have been checking my coolant levels every other day and the coolant in the Resevoir Tank keeps going down.
I had it pressure checked by two different shops and they both said it was fine. Nothing wrong that they could see.
Any ideas why it is losing coolant? I am afraid to let the coolant drain all the way from the Resevoir Tank in order to see if it over heats (then take it in to a shop saying it is overheating. thinking that could help figure it out.)
Jul 29, 2007 at 7:42 AM
DPWD23
  • 136 POSTS
If the neon has a seperate Resevoir tank (connected to radiator by thin low pressure hose) remove it and check that for leaks, and replace the hose.
If its a completely closed system, you can try replacing the cap.
what ever you do, do not let it overheat! thats one of the worst things you can do to an engine.
[quote:45f37ebb49="hockmasm"]99 dodge Neon, 130,000 miles, 4cyl Single Overhead cam, stickshift
Any ideas why it is losing coolant? I am afraid to let the coolant drain all the way from the Resevoir Tank in order to see if it over heats (then take it in to a shop saying it is overheating. thinking that could help figure it out.)[/quote:45f37ebb49]
Jul 29, 2007 at 9:26 AM
HOCKMASM
it does h ave a seperate tank. with the little hose.
i will check it out. you are saying the hose my have a hole in it?
i never see any fluid under the car except condesation from the AC.
Jul 29, 2007 at 10:44 AM
