1998 Dodge Neon Timing Belt Replacement
It's a big job to do, and since the timing belt and water pump are in the same vacinity, replace them both. Water pumps go bad too.
Chris
Indyuke--you need to be a moderator! Your help is needed with this team. :wink:
Another thought on it, If it breaks and you don't know why you car isn't starting, you are are now looking at diagnosis time, towing, inconveniece. Hopefully it happens when you aren't on the way to somewhere important.
Suggested Repair
Replace the timing belt and water pump together, typically around 60,000 to 90,000 miles. Do not rely only on a visual check, because a belt can fail even if it looks good and a break can cause major engine damage. A qualified independent shop can do the job; a dealership is not required.
Conversation Summary
The owner of a 1998 Dodge Neon 2.0L DOHC with about 69,600 miles asked whether the timing belt and water pump should be replaced and whether a Chrysler dealer was best. An expert recommended replacing both together every 60,000 to 90,000 miles because they are in the same area and a broken belt can severely damage the engine. Another owner said a belt that looked good lasted to 110,000 miles, but an expert warned that appearance is not reliable and failure can lead to towing and diagnosis costs. A later request for help with a stuck pulley was not answered.
