1998 Dodge Neon Timing Belt No Start
IPARDO
Hello, I want to introduce myself and also ask for assistance as my Dodge Neon is giving me problems, here's what happened:
While driving the water pump locked up(too old) and the timing belt came off and ripped.
I took the car appart, replaced the water pump, the belt and the engine motor mount, unfortunately the book (Chilton) says that you have to get a DRB tool and have the computer re-learn the crankshaft position other wise the timiong will be off and the car will not run, so what the car is doing is misfiring and not starting.
I have tried to get the tool and most auto parts can only offer a OBD tool that gives you the diagnostic but can not reset the computer.
Does anyone know how to set the timing or any tricks on what I can do??
This is frustrating as I did all the hard work so the dealer would not take a bite off my money, but now I am stuck with a dead car.
Any help will be appreaciated, I am in Illinois, (Chicago)
Tks.
Jan 12, 2006 at 4:23 AM
2CARPRO JACK
  • 11,533 POSTS
If the Cam and Crank timing are lined up according to factory marks then it will run
Feb 7, 2006 at 9:13 AM
BORIS
Hi, I got a 98 neon its a little over 185K haven't replaced the timing belt yet, do you have any idea when they need replacement?
Thanks,
Boris
Jan 16, 2007 at 1:02 PM
Suggested Repair
Align the camshaft and crankshaft to the factory timing marks. If both are correctly lined up, the engine should run without a special computer relearn tool.
Conversation Summary
A 1998 Dodge Neon owner reported that a seized water pump caused the timing belt to come off and tear. After replacing the water pump, timing belt, and engine mount, the car misfired and would not start. The owner believed a dealer DRB tool was required for the computer to relearn crankshaft position. The expert advised that the engine should run if the camshaft and crankshaft are aligned to the factory marks. A later question about timing-belt replacement interval on a high-mileage 1998 Neon was not answered.
