timing timing belt broke and replaced
208,000 MILES • 2.0L • 4 CYL
DEBBIE WRIGHT2
Timing belt broke replaced belt water pump head resurfaced/new gaskets, repaired all. have a broken motor mount? apparently was repaired not replaced. service engine soon light comes on/says off one tooth also using fuel quickly. what is the problem?
also, randomly two times has suddenly over heated in less than ten minutes. any and all help is appreciated.
May 26, 2017 at 12:58 PM
  • 55,817 POSTS
Yep it sounds like the timing belt is off one tooth which can cause both of the problems you have described, here is a link to the timing belt diagram and a guide to check for a blown head gasket or cracked head.
https://www.2carpros.com/diagrams/dodge/neon/1998
and
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 29, 2017 at 6:55 AM
