2001 Dodge Neon Timing Belt Snapped
JEWLSTEP
I have a 2001 Dodge Neon with 177,000 miles on it .
The timing belt snapped when I was on the highway. They are telling me i have an interference engine and have a 50-50 shot that just replacing the timing belt will fix my car . Then he told me that there is a 50 % shot that they can replace the belt and there's more damage and replacing the belt didn't work at all . What would you do ?
Mar 21, 2006 at 12:53 AM
The 2.0L engine is an interference engine so if the timing belt snapped while driving then move then likely you did contact the pistons to valves.
This does not mean that you damaged the engine but what we need to do is replace the belt and set the timing.
Then we need to turn the engine over by hand using a wrench on the crank pulley making sure that the engine doesn't lock up and is able to make two complete revolutions to ensure we open and close all the valves.
If it does, then we need to do a compression test to see if we have any bent valves. If we do, then we will have low compression on those cylinders.
Once we run through all this info, we will have a better idea if the engine is hurt. If the compression test passes, then we should be good to go.
Let me know if you have questions on this.
Thanks
Apr 18, 2022 at 2:49 AM
Suggested Repair
Replace the timing belt and set the timing, then rotate the engine by hand two full revolutions on the crank pulley to confirm it does not lock up. If it turns freely, perform a compression test to check for bent valves. If compression is good, the engine should be serviceable.
Conversation Summary
A 2001 Dodge Neon with 177,000 miles had its timing belt snap on the highway. The owner was told the 2.0L is an interference engine and that belt replacement might or might not fix it. The expert confirmed piston-to-valve contact is likely but not proof of major damage, and advised installing and timing a new belt, hand-rotating the engine two revolutions, then compression-testing for bent valves before deciding the engine is okay.
