2003 Dodge Neon Jerks on Downshift
MITZIOWSLEY
I have 2003 dodge Neon with 74000. miles on it.it has an auto transmissions and the engine is a 2.0
I made a trip to Orgen and my car would not go in gear the transmisson fluid was leakin on the groud
I had it tow back to calif. I went to the dealer and they told me I needed a new radiator mine had transmisson fluid in it and small holes. . I replace the radiator and had the transmissions flush. now my car is jurking when it is down shifting .
Thank you Mitzi Owsley :cry:
May 26, 2007 at 4:37 AM
E40WATER12
  • 522 POSTS
Sounds like youre tranny needs to have the dealership, upload new flash software into youre tranny system. Sounds like a common tail of Limp mode or bump shift, I would also ask what kind of tranny fluid that was used in the tranny fluid change, Maybe they didnt put in ATF+3 Or ATF+4 fluid.
May 27, 2007 at 5:00 PM
Suggested Repair
Have the dealer check for limp mode or bump shift and upload updated transmission software. Also confirm the flush used the correct ATF+3 or ATF+4 fluid.
Conversation Summary
A 2003 Dodge Neon with a 2.0 engine and automatic transmission leaked fluid, would not go into gear, and was found to have transmission fluid in a leaking radiator. After the radiator was replaced and the transmission flushed, it jerks during downshifts. The expert suggests a dealer transmission software update and verification that ATF+3 or ATF+4 fluid was used.
