2000 Dodge Neon Overheating
SANDYDEE01
I have 95,000 miles, 4cyl, 2.0 L. The car was overheating so I added 50/50 engine coolant. I used half of the container. 5 days later, it started to overheat again so I added the other half. Now 5 days later, which is now, it started to overheat again. The engine fan comes on, there does not appear to by any leak. I added it to the overflow tank. Should I be adding the coolant directly to the radiator? Could there be anything else be wrong?
Feb 15, 2007 at 2:27 AM
SERVICE WRITER
  • 9,123 POSTS
The coolant has to be going somewhere. You should fill the radiator when the engine is cold, and fill the reservior to the proper level.
Then run it, at idle and wait for the temperature to come up and see what is happening.
The thermostat may be stuck, is your heat real hot?
May be more serious problems such as head gasket if it is burning it. Is the exhaust white or a rough idle present?
Feb 15, 2007 at 4:00 AM
SANDYDEE01
I am in Florida so its difficult to tell about the heat. There is nothing white in the exhaust and it is not having a rough idle.
I am going to fill the radiator and see what happens
Feb 15, 2007 at 6:31 AM
SERVICE WRITER
  • 9,123 POSTS
I'm inclined to think the thermostat is stuck at this point.
Feb 15, 2007 at 7:23 AM
Suggested Repair
With the engine cold, fill the radiator and set the reservoir to the proper level, then idle and watch the temperature. A stuck thermostat is the most likely cause; a head gasket is less likely if there is no white exhaust or rough idle.
Conversation Summary
A 2000 Dodge Neon with 95,000 miles overheats repeatedly after coolant is added to the overflow tank. The fan runs and no leak is visible. The expert advised filling the cold radiator and reservoir, then monitoring at idle. White exhaust and rough idle were absent, so the expert leaned toward a stuck thermostat rather than a head gasket.
