1999 Dodge Neon Antifreez leak
ANTHONYHIL
  • 1999 DODGE NEON
1999 Dodge Neon 4 cyl Front Wheel Drive Automatic
I have a 1999 doge neon and I put some antifreez in it today and when I wen't back out to the car later that day there was no antifreez there. So can you tell me what I should check so i'll no what to get fixed?
Sunday, November 16th, 2008 AT 12:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Is the coolant underneath your car? You mean the coolant leaked out without the vehicle running? This is probably due to a hole in one of the radiator hoses, a faulty water pump, or cracked radiator. Inspect hoses for any cracks/holes or loose fittings. Check to see if coolant is dripping from water pump area.
Sunday, November 16th, 2008 AT 1:03 AM
