How do i locate and replace the thermostat in a 1996 Dodge Neon with 131000 miles.
Mar 2, 2006 at 4:11 AM
Locate the thermostat housing where one of the two large radiator hoses connects. It is typically held by a few nuts or bolts, with the thermostat inside. Use a vehicle-specific repair manual for the replacement procedure.
The owner of a 1996 Dodge Neon with 131,000 miles asked how to locate and replace the thermostat. The expert advised using a repair manual and explained that the thermostat is normally inside the housing where one of the large radiator hoses connects, secured by a few nuts or bolts.
