1998 Dodge Ram 1500 Won't Idle
SAMVLAVIGNE
my 1998 ram 1500 will not idle, it shuts off if i don't give it gas. does it need a new fuel filter??
Oct 8, 2007 at 11:51 AM
  • 110,251 POSTS
Hi:
It could be the filter or the pump. You need to check fuel pump pressure to the fuel rail. Here is a how to:
https://www.2carpros.com/dia/test_fuel_pressure.htm
If you don't have a gauge, some parts stores will rent the gauge or you can purchase one at the test equipment store site on this page.
Mar 10, 2009 at 8:18 AM
NITROJUNKI
I may be too late on this but check the idle control valve. If replaced, be sure to reset computer by disconecting the batt for a few minutes. This resolved my problem with my 1500 ram 98
Jan 5, 2011 at 4:56 PM
Suggested Repair
Check fuel pressure at the fuel rail to determine whether the fuel filter or fuel pump is at fault. Also inspect the idle air control valve; if it is replaced, disconnect the battery for a few minutes to reset the computer.
Conversation Summary
A 1998 Dodge Ram 1500 stalls at idle unless the driver applies throttle, and the owner asked whether a new fuel filter is needed. The expert said the filter or fuel pump could be responsible and recommended testing fuel pressure at the fuel rail, noting that a gauge can be rented or purchased. Another owner reported that replacing the idle control valve and resetting the computer by disconnecting the battery resolved the same problem.
