1996 Dodge Ram Low Idle Stalling
GOOBS19
i have a 1996 dodge ram 1500 4x4 5.9l w/ 135,000 mi. just had the torque converter replaced, that fixed my transmission shutter problem. Since then the truck seems to be idleing at lower rpm. and it stalls occasionally. It stalls after you hit the throttle in grear, then let off quik, then it dies. have any ideas? Im stumped. thanks...
Mar 18, 2007 at 2:32 AM
MINER49ER
1999 Dodge Durango 5.2 L 101000K miles. Check engine light came on and when i start from a stop (usually once the car is warm) then I lose power and feels like is it is going to stall but does not and a little jerking. I can punch the gas and that usually works. I have taken it into the shop and they looked over the transmission - flushed and put a new filter - put a new O2 sensor on it and still giving a bad code. I was told the main wire harness may need to be replace but they were able to find the wire from the O2 sensor that was giving a bad reading bypassed that. I am being told now that the PCM is at fault and will continue to mess with the O2 sensor, is this possible? Tny thougts woudl be nice.
THanks
Mar 18, 2007 at 6:28 AM
  • 55,694 POSTS
It sounds like your IAC motor is slow to re-act. Try replacing it and get back to us. :D
Mar 18, 2007 at 6:30 AM
GOOBS19
[quote:326ba4eccf="2CarPro Ken"]It sounds like your IAC motor is slow to re-act. Try replacing it and get back to us. :D[/quote:326ba4eccf] "goobs19" thanks man replaced iac motor, all fixed now. Thanks again.....
Mar 19, 2007 at 12:51 PM
  • 55,694 POSTS
Way cool, thanks for visiting 2carpros.com :D
Mar 20, 2007 at 3:57 AM
Suggested Repair
Replace the idle air control (IAC) motor. A slow-reacting IAC can cause low idle and stalling when the throttle is released, and replacement resolved the problem.
Conversation Summary
A 1996 Dodge Ram 1500 began idling low and occasionally stalling after a torque converter replacement, especially after the throttle was applied in gear and then released quickly. An expert suspected a slow-reacting IAC motor and recommended replacing it. The owner reported that replacing the IAC motor fixed the stalling. A separate 1999 Dodge Durango power-loss and sensor concern was also posted but was not the issue confirmed as fixed.
