my 1998 ram 1500 will not idle, it shuts off if i don't give it gas. does it need a new fuel filter??
Oct 8, 2007 at 11:51 AM
Check fuel pressure at the fuel rail to determine whether the fuel filter or fuel pump is at fault. Also inspect the idle air control valve; if it is replaced, disconnect the battery for a few minutes to reset the computer.
A 1998 Dodge Ram 1500 stalls at idle unless the driver applies throttle, and the owner asked whether a new fuel filter is needed. The expert said the filter or fuel pump could be responsible and recommended testing fuel pressure at the fuel rail, noting that a gauge can be rented or purchased. Another owner reported that replacing the idle control valve and resetting the computer by disconnecting the battery resolved the same problem.
