Check engine light has been going on and off for some time. Every mechanic I've taken it to has said to replace the plugs and wires, but I have already done that. Then, last week and again tonight, the car stalled out while going uphill while turning right or having just turned right and hitting a small pothole. Both times, the car would not turn over until some sort of impact to the front. A friend said it sounds like a bad solenoid. If so, any idea where it might be or, if not, what else it could be? Coil packs are good, plug sockets are good, plugs are good. The car makes a rattling noise too, at times, while driving, but mechanic said it was nothing to worry about, just something vibrating. Thanks.
1998 Dodge Intrepid Stalls
What about the blinking check engine light? Or the one that comes on and stays on throwing the random/multiple misfire code?
What about the blinking check engine light? Or the one that comes on and stays on throwing the random/multiple misfire code?[/quote:0933d85cc2]
Have the OBD2 pull and comeback w/the code
"Codes:
ENG: 106/P0302
Multi-Cylinder
Misfire
Temporary Codes:
ENG: 108/P0302
Cylinder #2 Misfire
ENG: 109/P0303
Cylinder #3 Misfire
ENG: 174/P0305
Cylinder #5 Misfire
ENG: 175/P0306
Cylinder #6 Misfire
ENG: 106/P0300
Multi-Cylinder
Misfire"
And that's all it ever says. The plugs were replaced and the wires were checked by two different shops and pronounced to be just fine. If it's not the plugs/wires, it has to be farther down/back, right? The solenoid or whatever's feeding into it is what I was told to get checked out.
HTH-Good Luck
plugs
wires
distributor cap
rotar arm in distributor
if u r missfiring either u have replaced the leads in the wrong sequence or the rotar is not making contact with the distributor cap properly u can get a full kit for around $20 this will give u a new cap and rotar
try that let me know how it goes
It died on me today as I was heading out for a job interview, only this time I couldn't get it to stay started after giving it some taps on the front. It would sometimes turn over, but would immediately start to shake and then shut off again.
could be a loose connection my friend had the same problam for months then i went and looked at it for him pulled on the live battery cable whist he tried to turn it over and it started something so simple
ppl miss
here is my yahoo id = newpcexpress
Thanks.
i havnt dealt much with oil preasur but i will give u a user name of someone who can help u
CHEVYII
he might be able to help you hes a moderator
Causes of Low Oil Pressure
Possible causes include:
Excessive main and rod bearing clearances (someone may have installed the wrong-sized bearings or standard-sized bearings on a reground crankshaft). Only 0.001" of extra clearance in the main bearings can reduce oil pressure by up to 20%!
Excessive camshaft bearing clearances (a bearing may have slipped out of place when the cam was installed).
Excessive clearances inside the oil pump.
Leaks between the oil pump and engine.
Oil pump relief valve stuck open or installed backward.
A loose or mispositioned oil pickup tube (too high in the oil pan).
A defective oil pressure sending unit or oil pressure gauge.
Low oil level in the oil pan.
Cracks or leaks in the oil galleries or gallery plugs.
Cracked oil pump housing (improper installation).
Oil viscosity too thin for hot weather.
Oil viscosity too thick for cold weather.
HTH-GooD Luck!
Suggested Repair
The stalling and misfires were traced to a failed crankshaft position sensor, which was replaced. For the oil warning light that remains on, verify the oil level and actual oil pressure, then check the oil pressure sending unit and other low-pressure causes such as pump, pickup, bearing clearance, or gallery leaks rather than assuming the sensor replacement caused it.
Conversation Summary
A 1998 Dodge Intrepid with about 99,000 miles stalled after bumps or right turns and set random and cylinder-specific misfire codes despite good plugs and wires. A friend suspected a solenoid, while replies suggested checking fuel pressure, scan codes, ignition parts, and battery or ground connections. The owner later reported that replacing the crankshaft position sensor stopped the stalling and a thorough engine check found nothing else wrong. The oil light then stayed on after adding oil and transmission fluid; replies pointed to possible low oil pressure and listed causes including a bad sending unit, low level, oil pump or pickup problems, leaks, and excessive bearing clearance.
