2001 Dodge Intrepid Rear Brake Grinding
GOLDGIRL1980
HI guys. I have a question for my 2001 Intrepid SE, 91000 miles, V-6 car. I think my rear drum brakes need a tune up/check. When I drive short distances they make no noise, but when I drive long distances, and I brake, the rear brakes make a grinding/metal on metal noise. It sounds horrible. The thing is, I don't have to dispress my brake pedal all the way to stop, just about half way. I can't remember the last time I changed my rear brakes, but had the front brakes replaced about 2 years ago. I don't want to put more strain on the front brakes and I don't want to wait to long as to cause more damage. Any thoughts would be great. Thank You. :D
Jun 4, 2007 at 12:12 PM
E40WATER12
  • 522 POSTS
If youre rear brakes are making noises like grinding, I would get them check out right away, Brakes are not to be left, Not function improperly, Risking youre safety for youreself and others.
Jun 4, 2007 at 8:40 PM
Suggested Repair
Have the rear drum brakes inspected immediately. Grinding or metal-on-metal noise can indicate worn brake components and should not be left unchecked.
Conversation Summary
The owner of a 2001 Dodge Intrepid SE with 91,000 miles reports rear drum brakes that grind after longer drives, even with moderate pedal pressure. The front brakes were replaced about two years ago, and the rear brakes have not been serviced recently. The expert advises having the noisy rear brakes checked right away because improper brake function is a safety risk.
