Brake pedal goes to floor
120,000 MILES • 3.2L • 6 CYL
DEE LEEMAN
New master cylinder, new brake booster, new knuckle, new rotors and brake pads. Brakes were bled no leaks anywhere, no loss of fluid. but the pedal does not stop the car. Took it to two different places and still does not stop. No one can fix the problem.
Please help me.
Deanna
May 21, 2017 at 10:00 PM
HMAC300
  • 48,601 POSTS
you will have to find a mechanic with a pro scanner because it has air in system he has to open valves in ABS unit then bleed brakes. Normally it is brake pressure modulator.
May 22, 2017 at 12:13 AM
