1996 Dodge Intrepid Brake pedal goes to floor
131,000 MILES • 6 CYL • FWD • AUTOMATIC
RONKRIS
Ok, recentlly purcased a 1996 Dodge Intrepid for my son. After changing the front brake pads the pedal goes to the floor and will not pump up with the engine running. So far I've bled the brakes several times and now have replaced the master cylinder with no change.
What am I missing here?
Oct 3, 2010 at 2:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check lines for leaks. does the pedal get stiff when pumping it when engine off?
Oct 3, 2010 at 2:43 PM
RONKRIS
[quote:bf179dd857="bluelightnin6"]check lines for leaks. does the pedal get stiff when pumping it when engine off?[/quote:bf179dd857]yes it does.Then goes to the floor again when engine is turned on.
Oct 8, 2010 at 1:35 PM
RONKRIS
yes it does then goes to the floor when engine is started
Oct 8, 2010 at 1:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is fluid getting to the brakes when you are bleeding them?
Oct 10, 2010 at 2:28 AM
