2003 Dodge Intrepid Headlights Dim
TAMMY1969
Hi, I have a 2003 Dodge Intrepid, 2.7l, and it has 150,000 km. The headlights and the dashboard lights keep dimming as well as the heater it kind of quits and starts the same time the headlights dim. I have changed the headlight switch, put in a new altenator and I also had info to do a headlamp switch connection where you just put in dielectric grease to the harness connector terminals. It is still dimming. What can I do? Even my mechanic is at a loss. He did suggest maybe putting in new battery cables, what do you think? I would really appreciate it if you can help me
Feb 6, 2007 at 9:08 AM
SERVICE WRITER
  • 9,123 POSTS
There is a ground (G200) that looks like it is common for the blower motor power module and the headlight switch. It is located at the lower center of the dash. I would check that for a poor connection, corrosion etc.
Feb 6, 2007 at 9:39 AM
Suggested Repair
Inspect ground G200 at the lower center of the dash for a poor connection or corrosion. It is shared by the blower motor power module and the headlight switch.
Conversation Summary
The owner of a 2003 Dodge Intrepid reports that the headlights, dashboard lights, and heater dim or cut out together. Replacing the headlight switch and alternator and greasing the harness connector did not help. The expert recommends checking shared ground G200 under the dash for a poor or corroded connection.
