2002 Dodge Intrepid No low beam headlights
75,000 MILES • 6 CYL • FWD • AUTOMATIC
HAGFAN05
My battery recently went bad. After replacing the battery I have no low beam lights...High beams are ok along with all other functions..I have checked all fuses in the system along with the relays. I am getting no voltage to the bulbs. I suspect the High/Low beam selector switch on the column..Any thoughts?
Jan 10, 2008 at 10:48 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a89d9c3683="hagfan05"]Electrical problem
2002 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 75000 miles
My battery recently went bad. After replacing the battery I have no low beam lights...High beams are ok along with all other functions..I have checked all fuses in the system along with the relays. I am getting no voltage to the bulbs. I suspect the High/Low beam selector switch on the column..Any thoughts?[/quote:a89d9c3683]
CHECK ALSO THE RELAYS IN THE POWER BOX UNDER HOOD
Jan 10, 2008 at 11:15 AM
