I own a 1995 Dodge Intrepid. I am trying to decide if compression gases are getting into my cooling system. What it does is after running a few minutes, the pressure cap releases and blows out coolant. I have tried another cap. Until then, it runs cool. It overheats after blowing out coolant. The heater always blows cold. I have removed the thermostat just in case that was the problem. I have tried bleeding it, but it never get a constant stream of water.. always some air or gases in there. Also, if you think that compression gases are getting in there, is it just a head gasket replacement, or could it be something else? Any and all ideas will be appreciated.
Feb 23, 2007 at 3:23 AM
