1996 Dodge Intrepid Oil Pump Knock
MEL_76_TX
I own a 96 dodge intrepid 3.5 v6 180,000 miles. Has never used,leaked or burned oil. While driving last week what sounded like the oil pump started "rattling or knocking" I checked the oil it read full. Oil light did not come on. I would like to find out what other parts connected to the oil flow could be making this noise.Since the pump cost $245 and about $500 in labor. Could it be the sludge in the motor I have been reading so much about? If it is the oil pump, is there any easier way to change it besides jacking car up and taking off "half" the parts to get to it? I have had this car 3 yrs and this is the first major thing to go wrong. I really hate to give up my car!
Feb 6, 2007 at 1:03 PM
  • 75,988 POSTS
Try an extreme engine flush to wipe out all that sludge/gooey, if not maybe a weak pump or a bearing problem.
Feb 7, 2007 at 9:10 AM
MEL_76_TX
Thanks! Im tring to get out as cheap as I can on fixing the car since I also have to replace a clutch on my 89 ford f150!
Feb 7, 2007 at 9:19 AM
Suggested Repair
Try an extreme engine flush to remove sludge. If the noise continues, suspect a weak oil pump or a bearing problem.
Conversation Summary
The owner of a 1996 Dodge Intrepid 3.5 reported a rattling or knocking noise that sounded like the oil pump. The oil level was full and the oil light did not come on. They asked whether sludge or another oil-related part could cause it and whether the pump could be replaced more easily. The expert suggested an extreme engine flush, and if that does not help, a weak pump or bearing problem.
