1996 Dodge Intrepid too much smoke coming out of muffler
1996 DODGE INTREPID
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
AZQUEST76
i have a 1996 dodge intrepid and when i start to drive for about 20mins, alot of smoke comes out of my muffler, especially when i hit the gas pedal at the stop lights. then it goes away...my temp. on the car is in the middle, so it;s doesn't look like it over heats or anything. Not sure what is wrong with? Could it be the coolant?...should i put 50/50 coolant?[img:4530f4d564]http://www.2carpros.com/forum/automotive_pictures/379616_f10e129d_1.jpg[/img:4530f4d564]
Jul 8, 2009 at 9:47 AM
  • 110,244 POSTS
Yes to the 50/50 coolant. What color is the coolant that comes out?
Jul 8, 2009 at 2:15 PM
  • 110,244 POSTS
I ment to say what color is the smoke that is coming out, and are you adding coolant on a regular basis?
Jul 8, 2009 at 2:16 PM
AZQUEST76
thanks for the respond, yes the smoke is white and i don;t put coolant in it everyday. should i put Prestone/Antifreeze and Coolant better than the 50/50 coolant? or the Peak/Long Life Antifreeze and Coolant. how do i drain out all of the old 50/50 anti freeze? So i can place the new one?
Jul 9, 2009 at 4:22 AM
  • 110,244 POSTS
Regardless of the brand of coolant, it needs to be mixed 50/50 with water. However, I have a concern. If you are getting white smoke from the exhaust, that means there is coolant getting into the combustion chamber and burning with the gas. It sounds like you have a bad head gasket.
What you need to do is check engine compression. Chances are you will find one of the cylenders has lower compression than the others. Here is a how to for checking compression:
https://www.2carpros.com/dia/how_to_check_compression.htm
Let me know what you find or if you have additional questions. Also, if you need the compression gauge, many parts stores will lend or rent them to you.
Thanks for using 2carpros.com
Jul 9, 2009 at 10:34 AM
