1991 Dodge Dynasty wont start
ALBY JAY
  • 1991 DODGE DYNASTY
  • 6 CYL
  • 150,000 MILES
This vehicle is one I bought then left sitting for 7 months. Didnt run while parked. I tried to start it and it wont start I changed the battery the plugs and wires as well as the starter. They needed to be changed anyways but I shot starting fluid into the carb it started while there was starter fluid in it but would not fire up like it was getting no gas. I put gas in it it has about 7 gallons in it now. I would really apreciate the help guys thanks.
Friday, August 8th, 2008 AT 12:20 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Is any of the fuel in your tank older than 1 month? If so then you need to drain it and put in new fuel. The best way to tell if this happens is to pour a small amount of gasoline into the throttle body. If it fires up initially then the gas is could be bad. Also check for proper fuel pressure and flow to the injectors.
Friday, August 8th, 2008 AT 1:16 AM
Related Engine Not Running Content
