1991 Dodge Dynasty Something pulling power
UNCRUBERT
  • 1991 DODGE DYNASTY
  • 6 CYL
  • 12,000 MILES
The 1991 dodge if I don't start it at least 3 times a day and run it I have to put the battery charger on itthe next day it won't start. Even in Hot weather. Someone told me to take off the cable from the battery and see if the car still runs, and it didI took out the fuse for the radio thinking that is pulling power but nothing. Is there a short somewhere in the doors or a broken wire pulling power? The car runs great besides this problem.
Thursday, March 12th, 2009 AT 7:29 AM
CARADIODOC
  • 33,916 POSTS
I assume you mean it still would CRANK after you took the battery cable off, right?
How much stuff do you have packed in your glove box? It is REAL common for excessive paperwork to bend the tab holding the glove box light switch so it doesn't turn off.
Three times a day seems like a lot to have to start it, but it is normal for it to kill the battery in a day or two. I seem to recall that light being on the same fuse as the interior lights. There is also a thermal timer for the light by the ignition switch. It is very rare for the contacts to stick, but if they did, it would also run the battery down in a few days.
I have a Dynasty with 3200 miles, but it's a '93 and has a body computer that controls the key light, not a thermal timer. It is normal for all the various computers' memory circuits to drain the battery, but Chrysler says it will still crank after three weeks.
Holler back if the glove box light is not the problem.
Caradiodoc
Friday, March 20th, 2009 AT 1:49 AM
BORGHESE
For Caradiodoc, I have a 92 dynasty that had the same problem. New battery drained in three days. The mechanic did a test, fuse by fuse, and found it was the #13 fuse, for the radio, glove box, etc. Draining the battery. It's not the glove box light, cigar lighter, speakers, and he narrowed down to the radio. I did not pull the radio (just pulled the fuse), but I have not heard of a timer for the ignition switch, could that have gone bad? Now I have no radio, lighter, glove box light, master lock on the driver's door, or the nice ring of light around the ignition switch.
Wednesday, June 15th, 2016 AT 8:27 PM
