2003 Dodge Durango starting problems
JPATTERSON84
  • 2003 DODGE DURANGO
Engine Mechanical problem
2003 Dodge Durango V8 Automatic
When I try to start it and turn the ignition it will not start and it makes this clicking noise what is the problem
Monday, July 20th, 2009 AT 8:25 PM
CARADIODOC
  • 34,367 POSTS
If you hear a single loud clunk from the starter every time you cycle the ignition switch, you have worn solenoid contacts in the starter. They cause an intermittent problem that will get worse over time. Replacement contacts are 20 bucks, but most people just replace the entire starter.
Caradiodoc
Saturday, August 8th, 2009 AT 2:37 AM
