2003 Dodge Durango Wont start after driving for a while
ERIC LANE
  • 2003 DODGE DURANGO
  • V8
  • 100,000 MILES
Sometimes my vehicle will start and run for a while, but when I shut the engine off my vehicle will not restart. If I let the vehicle set for a few days and try to start the vehicle, it restarts and runs, but repeats itself and will not restart when I shut the vehicle off.
Friday, May 28th, 2010 AT 1:46 PM
Next time it will not start do below to determine if its fuel or spark that's causing it
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, May 28th, 2010 AT 3:48 PM
