2000 Dodge Durango Door Lock Screech
SHAR
I have a 2000 Dodge Durango. When locking or unlocking my power door locks, it makes a horrible loud screeching noise on the drivers side. It happens in all aspects of the power lock (using keyless remote, the button on the door panel, and automatic locking when reaching 15mph. Also, the keyless remote won't lock the drivers side, I have to use the key manually.
As for the power window problem, the back windows don't work at all from any of the power buttons. They use to work intermittantly, but now not at all, and no the child lock is not on.
I would like to fix this myself if possible, priority being the door locks.
Thanks,
Please Help!!
Shar :roll:
Dec 17, 2006 at 5:22 PM
2CARPRO JACK
  • 11,533 POSTS
The door lock problem sounds like the lock actuator.Some Dodges its integrated into the latch assembly, but is servicable seperatly.The windows you will need to pop the switches out of the door panels and test for power out in the up and down positions and for ground at the switches.If the switches are working properly then it might have a bad set of motors. Seen stranger things
Dec 18, 2006 at 3:37 AM
Suggested Repair
The driver's door lock screech and remote lock failure point to a faulty lock actuator, which on some Dodges is part of the latch but can be serviced separately. For the rear windows, remove the door-panel switches and test for power in the up and down positions and for ground. If the switches test good, suspect bad window motors.
Conversation Summary
The owner of a 2000 Dodge Durango reports a loud screech from the driver's side whenever the power locks operate, including by remote, door button, and automatic lock. The remote also will not lock the driver's door, so the key must be used. The rear power windows no longer work from any switch after previously working intermittently, and the child lock is off. The expert attributes the lock issue to the lock actuator and advises testing the window switches for power and ground before suspecting the motors.
