1999 Dodge Durango Wipers Stopped
SPI3050
I own a 1999 dodge durango, this morning I went to start my it and turned on the wipers. They started working just fine and then stopped. COuld this be a simple fuse problem or something bigger.
Nov 29, 2006 at 4:43 AM
BRUCE HUNT
  • 3,754 POSTS
If it was a mechanical problem then you are looking at little work. But if the fuse went which is what I would want in order to save the motor, etc then I would obviously start there. It can always be the switch as well.
Nov 29, 2006 at 6:28 AM
Suggested Repair
Start by checking the wiper fuse, then the wiper switch. A mechanical problem is also possible and may require less work.
Conversation Summary
The owner of a 1999 Dodge Durango said the wipers worked briefly after startup and then stopped, and asked whether a fuse or a larger fault was likely. The expert advised starting with the fuse to help protect the motor, noted the switch as another possibility, and said a mechanical problem would involve relatively little work.
