1999 Dodge Durango O2 Sensor Location
1999 DODGE
FROG6969
hello i have a 1999 dodge durange i know the O2 senser is bad and the code machine says bank 1 slot 2 where is that senser? oooo i have went throw 3 water pumps in 2 years why
Mar 27, 2007 at 9:17 AM
MERLIN2021
  • 17,250 POSTS
Bank 1 sensor 2 is the side your #1 spark plug is the second sensor...usually after the catalytic converter.
Try putting in a NEW water pump not a rebuilt next time you need one!
Mar 31, 2007 at 3:29 PM
Suggested Repair
Bank 1 sensor 2 is on the same side as the #1 spark plug and is the second oxygen sensor, usually after the catalytic converter. For repeated water pump failures, install a new pump rather than a rebuilt unit.
Conversation Summary
The owner of a 1999 Dodge Durango asked where the bank 1 sensor 2 oxygen sensor is located and why three water pumps failed in two years. The expert said bank 1 sensor 2 is on the #1 spark plug side and is the second sensor, usually after the catalytic converter, and recommended a new water pump instead of a rebuilt one next time.
