2001 Dodge Durango High Idle
HEBIGCHIEF
I have a 2001 Dodge Durango 4x2 4.7 V-8 with 54,000 miles on it. One day the truck just started to idle high after start up( about 1800 rpm) and would only come down if you rap the gas quickly like an old carbureted auto. After you rap the gas the idle will be normal for a while, but will return high once again during start and stop driving or when you turn the a/c on. If you rap the gas again several times the idle will return to normal again, but will eventually go high again. I had it at the dealer and several reputable shops and all report NO vacuum leaks and no codes stored in the computer. I have had the IAC replaced, the throttle body cleaned 2 times, an induction cleaning service, the fuel injectors flushed, the spark plugs replaced and the air filter replaced. The only thing that helped for a short period of time (several days) was the new IAC motor! Can someone PLEASE HELP???
Apr 4, 2007 at 12:26 AM
  • 75,988 POSTS
Could be the throttle plate needs cleaning
Apr 4, 2007 at 12:35 AM
HEBIGCHIEF
[quote:798e610bf6="rasmataz"]Could be the throttle plate needs cleaning[/quote:798e610bf6]
As stated I have had the throttle body cleaning perfomed 2 times...is cleaning the throttle plate a different service?
Apr 4, 2007 at 1:49 AM
  • 75,988 POSTS
Inspect the butterfly and readjust the acc. cable IAW the manual meaning the clearance.
HTH Good LUck!
Apr 4, 2007 at 8:51 AM
Suggested Repair
Inspect the throttle butterfly and readjust the accelerator cable to the clearance specified in the service manual.
Conversation Summary
The owner of a 2001 Dodge Durango reports a high idle of about 1800 rpm after startup. Blipping the throttle temporarily restores a normal idle, but the high idle returns during stop-and-go driving or when the A/C is turned on. Shops found no vacuum leaks or stored codes, and replacing the IAC, cleaning the throttle body twice, performing an induction service, flushing the injectors, and replacing the plugs and air filter did not provide a lasting fix. An expert suggested inspecting the throttle butterfly and readjusting the accelerator cable to the specified clearance.
