high idle and accelerating slowly on its own
4.7L • V8 • 4WD
DILLONSWED
We did a head job on the durango runs great except the idle is high when in park about 2000 rpm when put in drive its wants to accelerate through 3rd gear it feels now I can hear a vacume leak it seems coming from the throttle body but when I cover my hand over it to see if there is one the truck chokes a d dies like there isnt replaced the tps cause I figured that might have been a problem being how the check engine light says tbs low circuit and another saying tps high circuit still does the same tbing clear the dam code and still there hope this is detailed enough please help
Mar 12, 2014 at 2:22 PM
  • 110,248 POSTS
Have you tried using carb cleaner to check for a vacuum leak? Also, have you checked the idle air control valve?
Mar 12, 2014 at 10:28 PM
DILLONSWED
So ya we checked the sensor and sprayed throttle cleaner and didnt find anything took the air intake off and noticed oil on the driver side around the manifold and a valve seems to be stuck open could this be the problem?
Mar 13, 2014 at 1:08 PM
  • 110,248 POSTS
What kind of valve?
Mar 14, 2014 at 1:39 AM
DILLONSWED
Cylinder valve stem intake side and is there anyway to replace it without removing the head?
Mar 14, 2014 at 2:17 AM
DILLONSWED
Changed the valve and spring still idling high n accelerating slowly by itself
Mar 15, 2014 at 3:50 AM
  • 110,248 POSTS
I feel you have a problem with the IAC or a vacuum leak.
Mar 19, 2014 at 12:41 AM
