1999 Dodge Durango Antifreeze Smell
SUPERDAVE
Similar to another question asked in the forum. Antifreeze had broken down, got system flushed and shorlty after started to smell antifreeze when heating of cooling system was used. Took to local Dodge dealer to repair speed sensor on rear wheel and to have them pressure test cooling system (I had initially thought it was a heater core) The tested system & found no leaks, they then cleaned some box in the system and used "mr fridgy fresh?" in the process... The smell was gone for a couple days, but then returned. Any ideas on a final solution to this problem?
Apr 24, 2007 at 7:53 AM
2CARPRO JACK
  • 11,533 POSTS
If there isnt any leaks contaminating th eplenum, then time and Ozium
Apr 24, 2007 at 11:35 AM
SERVICE WRITER
  • 9,123 POSTS
Is the coolant level dropping at all? IF you turn on the defroster is there anything abnormal happening?
Apr 24, 2007 at 1:32 PM
SUPERDAVE
[quote:cfa4fac4ee="Service Writer"]Is the coolant level dropping at all? IF you turn on the defroster is there anything abnormal happening?[/quote:cfa4fac4ee]
Defroster works fine, no moisture on windshield present. Carpet not wet, smell is primarily when vent fan is turned on (heat or AC).
Apr 25, 2007 at 12:22 AM
SERVICE WRITER
  • 9,123 POSTS
Yeah, gotta go with Jack on that.
Walmart probably has it as well.
I think that is a 5.2 motor.
Apr 25, 2007 at 2:19 PM
Suggested Repair
With no pressure-test leaks, wet carpet, or windshield moisture, treat residual coolant odor in the HVAC plenum with an odor eliminator such as Ozium and allow time for the smell to fade. Confirm the coolant level is not dropping.
Conversation Summary
A 1999 Dodge Durango developed an antifreeze smell after a cooling-system flush, mainly when the vent fan ran on heat or A/C. A dealer pressure test found no leaks; cleaning a system box and using an odor product only briefly helped. The defroster worked normally, with no windshield moisture or wet carpet. Experts said that if coolant is not contaminating the plenum, the remaining remedy is time and an odor eliminator such as Ozium. One expert also noted the engine is likely a 5.2 rather than a 5.3.
